Viewing 7 posts - 31 through 37 (of 37 total)
  • asifak Friend
    #407013
    I upgraded JA Front Page module in the JA Extensio Manager. Now, new versio is 1.4.0. However, when I configure it in the Modules section, neither ‘SAVE’ nor ‘APPLY’ works. ????????
    Manos Moderator
    #407014
    In order to upgrade non ja modules/plugins etc you have to create a local repository!
    Please check this for helping you out with issues regarding JA Ext Manager -> http://www.joomlart.com/blog/joomla-extensions/ja-extensions-manager-upgrades-/-rollbacks-made-easy-free-for-all
    Manos
    Blaine Friend
    #407109
    Please downloading file “ja.tooltips.txt”
    It can be found on this thread:
    http://www.joomlart.com/forums/topic/extensions-manager-1-5-4-does-not-work-with-mootools-upgrade-plugin/
    Thanks!
    asifak Friend
    #407203
    hi Blaine,
    I downloaded the file ja.tooltips.txt and changed it to ja.tooltips.js and uploaded to the required directory. Whats up now ??
    Blaine Friend
    #407340
    Hi asifak,
    Did you follow the directions on the thread I referenced?
    If so, is the problem resolved?
    Make sure to force a clear of your browsers cache by hitting the CNTRL key at the same time as the F5 key just to be sure of what you are seeing.
    Thanks!
    asifak Friend
    #407579
    Yes, I followed the thread instruction. I checked in the JA Extension manager for Mootools upgrade and it gives the following same message;
    Response from JoomlArt Updater Service: Sorry, this extension is invalid, unpublished or no longer supported
    Please update the service setting or contact with service provider.
    Blaine Friend
    #407689
    Hi asifak,
    I have reported this bug to the devs.
    We will let you know when there is a solution.
    Thanks!
This topic contains 37 replies, has 6 voices, and was last updated by  Blaine 13 years, 3 months ago.
