  • David Porré Friend
    #159298
    I’m using JA Top Panel with auto open mode, I would like it to “auto close” after a few seconds, for my visitors not to be bothered…
    Would it be possible ? How ?
    Hoping for answers,
    Best regards,
    David aka Shapes
    #373864
    Dear shapes,
    You can try as following
    Open the file of modules/mod_jatoppanel/assets/script.js,Looking for the snap of code
    if(this.options.auto){
    $clear(this.timer);
    this.timmer = this.openPanel.delay(this.options.delay, this);
    } change it to
    $clear(this.timer);
    this.timer1 = this.closePanel.delay(this.options.delay+3000,this);
    } Then look for the function
    openPanel: function(){
    this.myslider.slideIn();
    this.myslider.slideOut();
    if(this.options.dontshowagain){
    this.controlButtonDontshowagain($(‘ja-toppanel-button-subwap-‘+this.options.modulenid))
    if(this.options.overlay){
    this.overlayFx.start({
    ‘height’: [0, window.getSize().scrollSize[‘y’] + this.content.offsetHeight],
    ‘opacity’: [0, 0.7]
    }, Add this function below it
    ‘opacity’: [0, 0.7]
    closePanel:function(){
    this.myslider.hide();
    }, I hope these would help !
    David Porré Friend
    #389969
    Sorry for my late answer, I didn’t see your post.
    I just tried your modifications, but it didn’t work.
    The top panel didn’t show at all anymore.
    Thanks anyway for your effort,
    Please keep me in touch if you have any other idea.
    Best regards,
    David aka Shapes
This topic contains 3 replies, has 2 voices, and was last updated by  David Porré 13 years, 6 months ago.
