  • aledev Friend
    #177529
    Hi everyone !! Great job with these products !
    Is possible to move ja top panel module on right-side o left-side ??
    An example here: http://www.joomlart.com/demo/#joomla17-templates.joomlart.com/ja_elastica
    I would use ja top panel module like DEMO BUILDER on the left.
    Thanks !
    Gianca
    #454986
    Hi alevev,
    As you can see, in the module back-end there are not options for showing module at the left-side or right-side, you would need to customize into the module to get it display that way, it would be a heavy customization and I think you should find a talent freelancer with a small fee to get help in this case.
    I hope you understand 🙂
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 12 years, 7 months ago.
