  • kidi Friend
    #180687
    ( Joomla! 2.5.6 Stable – Ja-Travel – Plugin Ja-Typo 2.5.2 – Ja-Typo buton 2.5.3)
    Hope I will be clear on my explain.
    When I chose a buble with the ja-typo buton, the design is good on the backend admin (look picture join).
    When the article is online the color change in gray (the little arrow too).
    When I look the code with Firebug the code with the good color is not available.
    I join pictures for explain with visual.
    Thank you in advance for your help :))
    1. Ja-typo-pb
    2. Ja-typo-code-pb
    HeR0 Friend
    #467166
    Hi Kidi
    I think that you should check ja typo plugin which is loaded on front end, isn’t it?
    Regards,
    kidi Friend
    #467254
    Hello HeR0,
    Thank you for take time with my question.
    Fontend : In the code, on Firebug, the link of the code is good (jatypo plugin files).
    I desinstalled and re-install the plugin. Same problem.
    With the original code, on Ja-Travel , the design is ok but, of course, I prefere use the plugin than copy/past the code each time I want a buble or a box from “Typography additional options” page.
    HeR0 Friend
    #467322
    Ok Kidi, it is good idea. But remember that you need some customizations to do this, you must remove css style applied for comment blue by template style…
    Regards,
    kidi Friend
    #467758
    Hello HeR0,
    I change the name of the files typo.css on templates/j_travel/css/
    And Ja-typo run very well.
    Thank you for your response, it is exactly that ! 🙂
This topic contains 5 replies, has 2 voices, and was last updated by  kidi 12 years, 3 months ago.
