  • gzinic Friend
    #968274
    Ja University has by default 75% main content and 25% right column width. I would like to change it to 68% main and 32% right. How can I do that?
    Thank you, Goran
    1. width
    Pankaj Sharma Moderator
    #968318
    The width is defined in the php files in form of columns .
    Go to /templates/ja_university_t3/tpls/blocks/mainbody/one-sidebar-right.php
    Find
            <div id="t3-content" class="t3-content col-xs-12 col-sm-8  col-md-9">
    change the col values .
    Same for sidebar
            <div class="t3-sidebar t3-sidebar-right col-xs-12 col-sm-4  col-md-3 <?php $this->_c($vars['sidebar']) ?>">
    Make sure total value should be 12 .
    If content has col-md-3 then sidebar has col-md-3 = 12
    gzinic Friend
    #968524
    Thanks for reply but there’s no tpls folder on my installation. I’m using T3v2.
    #968604
    You can apply the suggestion given in this thread for old version of JA University .
    Take backup of site before applying changes .
    Hope it helps .
    gzinic Friend
    #968720
    Thanks.
    T3 is newer than T3v2 ?
    #968773
    Yes to new framework with different new features .
    sushismb Friend
    #989303
    Hello @pankaj Sharma
    After installation of the template, I found that there was something wrong with the column width of the content-mass-top and the sidbars.
    I don’t know how did this happen as this is how it become after installing the quickstart.
    Please help!
    Thank you!
    1. screenshot-localhost-2016-11-24-15-29-30
    2. screenshot-localhost-2016-11-24-15-37-59
    #989311
    Hi @sushimb
    Since your topic is different then the discussion of this thread i request you to open your own thread with issue description and site details .
    It also helps other user to find solution for the same topics.
This topic contains 7 replies, has 3 voices, and was last updated by  Pankaj Sharma 7 years, 11 months ago.
