  • lanesa Friend
    #180877
    Hi the slideshow just disappeared… After i launched it and the visitors browsed the site for about 24 hours then the header just disappeared.
    lanesa Friend
    #467805
    <em>@lanesa 339253 wrote:</em><blockquote>Hi the slideshow just disappeared… After i launched it and the visitors browsed the site for about 24 hours then the header just disappeared.</blockquote>
    The slideshow only displays when you type the domain without http://www... Can someone point me into the right direction with another post that has some similar issues with the slideshow not displaying. Thanks!
    tfosnom Friend
    #467813
    Try this
    In your configuration.php file put the full url (http://www.yoursitedomain.com) into the field . . . live_site = ” ”; located around line 20
    Blessings Shannon
This topic contains 3 replies, has 2 voices, and was last updated by  tfosnom 12 years, 2 months ago.
