January 29, 2017 at 11:00 pm #1006623
setting the start and end levels is not functional. (in the position "mainnav")
I would like to use in megamenu only start level 2.
Is it possible?Thank you
Karel
January 30, 2017 at 5:59 am #1006691Hi
When you use the Mega Menu it will not use the Menu module part. You have to control the menu from Mega Menu options.
If you want to use Menu module, Disable the Mega menu and use your Menu module.
Hope it helps.
RegardsJanuary 30, 2017 at 7:45 am #1006716Unfortunately i didnĀ“t found this setting in mega menu options.
It is not functional when i disable mega menu.
When i use another position (for example position1) then setting the start and end levels is functional.I need start level 2 in the position "mainnav".
Karel
January 30, 2017 at 7:57 am #1006717i need this menu in homepage – http://www.opravypocitace.cz
and by sports club i need – http://www.opravypocitace.cz/judo2 (it is bad in position "mainnav" and it is right in position "position1" (under slideshow)
January 30, 2017 at 8:06 am #1006718Hi
The Main nav position loads the Mega menu style files. In this case you have to use it on other positions.
Or you can use two different menu item in two different template styles from template options.
Hope it helps.AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 4 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 7 months ago.
JA University T3 – problem with Megamenu start and end level (Joomla! 3.6.5)
