  • jcata Friend
    #189149
    I have installed the quickstart of Ja_hawkstore.
    I made this modification in VM categories to create a subcategory:
    -Skateboards
    -Wheels
    After create a subcategory, if I go to module Wheels type JA VM Products doesn’t work in Backend (in Frontend all is correct). Seems a recursively problem.
    Could you solved it or propose a solution?
    Thanks,
    phong nam Friend
    #499857
    Hi jcata,
    I will check & give you the suitable solution if you can send me PM with your website’s credentials
    jcata Friend
    #499873
    Hi Leo,
    just install the quickstart, create a VM subcategory and try to assign the module with this VM subcategory and you’ll see the bug when you enter in the module.
    Thanks!
    phong nam Friend
    #499876
    Hi jcata,
    You are right. There is still a bug on selecting VM sub-categories in the backend of our JA VM Products module. In order to solve this issue, you need to open modulesmod_javmproductsassetselementsvmcategories.php, the replace line (112th):
    self::categoryListTreeLoop ($selectedCategories, $childId, $level, $disabledFields);
    with
    $categoryTree .= ShopFunctions::categoryListTreeLoop ($selectedCategories, $childId, $level, $disabledFields);
    Save. You can select & display the VM sub-categories then. We will include this bug fix of JA VM Products module in next update of quickstart version.
    @moon Sailer: Thank for your tip !
This topic contains 4 replies, has 2 voices, and was last updated by  phong nam 11 years, 5 months ago.
