  • chieftec Friend
    #942486
    is it possible to show some short description and text length on each product which is shown under eg. featured products? Like in categorie layout?
    Thank you!
    Pankaj Sharma Moderator
    #942704
    To add the description in the Virtualmart Product module , please check the suggestion given Here on Virtualmart forum .
    Please note there is an override of the Product module inside the template folder , so u need to apply changes in this file too .
    Here is path of override : templates/ja_techzone/html/mod_virtuemart_product/default.php
    Hope it helps .
    chieftec Friend
    #942782
    Hi, thanks for your reply. The how to is okay, but I can’t find some special parts like in the mod_virtuemart_product.php
    if (!class_exists( 'VmModel' )) require(JPATH_ADMINISTRATOR.DS.'components'.DS.'com_virtuemart'.DS.'helpers'.DS.'vmmodel.php');
    This part is missing.
    #942813
    Hi you need to at the code manually because it’s an override and doesn’t contain all the codes.
    Let me know if it works
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 6 months ago.
