sanjiovani Friend
sanjiovani
- September 2006
December 1, 2014 at 7:22 am #203200ja wail k2 images and top right module cut off by header
I increased the size of the header and my content at the top are now cut
any suggestions for a fix would be appreciated
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
December 1, 2014 at 6:36 pm #557251So that I can try to best assist you, please check the site admin login info you provided.
I have tried several times with the provided info, but it doesn’t seem to work.:((
sanjiovani Friendsanjiovani
- September 2006
February 25, 2015 at 8:47 am #560620Hello Tom – I sent you a private msg with my login information – thanks
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
February 27, 2015 at 10:41 am #560924Hi @sanjiovani,
Please temporary disable CSS compression so I can take a look at the code.
- September 2006
April 6, 2015 at 8:40 pm #565997Done
Looking forward to a solutions
Thank you
- May 2014
April 7, 2015 at 4:14 am #566028Hi @sanjiovani,
Please open file root_folder/templates/ja_wall/css/template.css then add this code at the end of file :
#container #sidebar {
top: 106px;
#container .main {
padding-top: 106px;
}sanjiovani Friendsanjiovani
- September 2006
April 7, 2015 at 7:42 am #566063just added the code – unfortunately no change
- May 2014
April 8, 2015 at 3:47 am #566262Hi @sanjiovani,
I checked your site but still see the old code, please make sure to clear your Joomla! / browser / JA T3 (in admin panel) cache and recheck.
Update : Please also disable CSS compression / minify as well so I can check the change.sanjiovani Friendsanjiovani
- September 2006
April 8, 2015 at 8:48 am #566305I have changed the code and checked in template.css files on the server – cleared cache, compression is turned off – still not working
- May 2014
April 8, 2015 at 4:05 pm #566337Hi @sanjiovani,
I tried connect to your site using FTP account provided in another thread, modify template.css file but didn’t see the change update in front-end. I even try to rename current template folder and see it won’t change as well so there might be file caching in your server.
Please recheck to see if there’s any 3rd party extension that cause this problem or contact your hosting provider about this matter.
- September 2006
April 9, 2015 at 4:44 am #566407I am using cloudflare – would that impact the caching ?
- May 2014
April 9, 2015 at 7:52 am #566444Hi @sanjiovani,
Yes, please temporary disable it as well and let me know then I can recheck for you.
- September 2006
April 9, 2015 at 8:45 am #566458I got the cache working and it looks fine now
- May 2014
April 10, 2015 at 3:22 am #566532Hi @sanjiovani,
Glad to hear that you managed to sort it out. Please keep it disable as I will need to work with CSS code in another thread you opened.
If you still have any question, don’t hesitate to let me know.
This topic contains 14 replies, has 3 voices, and was last updated by Adam M 9 years, 6 months ago.
