  • bowman999 Friend
    #185800
    Hi wall users,
    Can anyone recommend to me the best Joomla 3 cache settings when using JA Wall? Seems to run a bit slow on occasions.
    Would love to hear from anyone that has achieved good results using server side caching too.
    Cheers,
    John
    Hi John,
    – You can check this guide to know more about cache settings of joomla: http://docs.joomla.org/Help30:Site_Global_Configuration#Cache_Settings
    – Reconsider the usage of the “important” plugins and modules, sometimes switching them off is better, the same with unused content, remove them to reduce query
    – Check with your hosting provider to have Server settings and a good htaccess. here is an useful tips for cache with httaccess: http://www.askapache.com/htaccess/speed-up-sites-with-htaccess-caching.html
    Regards.
    bowman999 Friend
    #486675
    I was actually after specific cache settings that were good for JA Wall (that work well for the masonary script, etc).
    However, thanks for the link, I’ll check it out.
    Cheers,
    John
This topic contains 3 replies, has 2 voices, and was last updated by  bowman999 11 years, 9 months ago.
