  • jkriordan Friend
    #179780
    This evening I started getting an error message in my Wall from the Facebook Social Plugin.
    It tells me that a URL is unreachable, and when I click on the URL I’m taken to FB Debugger, which reports response #206, and tells me:
    Inferred Property: The ‘og:url’ property should be explicitly provided, even if a value can be inferred from other tags.
    Inferred Property: The ‘og:title’ property should be explicitly provided, even if a value can be inferred from other tags.
    Inferred Property: The ‘og:description’ property should be explicitly provided, even if a value can be inferred from other tags.
    Inferred Property: The ‘og:image’ property should be explicitly provided, even if a value can be inferred from other tags.
    Tiny og:image: All the images referenced by og:image must be at least 200px in both dimensions. Please check all the images with tag og:image in the given url and ensure that it meets the minimum specification.
    I haven’t made any direct modifications to my Wall source code. Social Plugin worked fine before. Can anyone suggest a solution?
    Upon inspecting my source code, I don’t find any of these properties. How can I tell Joomla to add them?
    I added a Contact Form and Feedgator to my Wall today. Could this have anything to do with it?
    I really need to solve this problem. I’m getting this error message on just about every article on my site.
    Thanks in advance!
    Upon inspecting my source code, I don’t find an og:url property. How can I tell Joomla to add it?
    Thanks in advance!
    jkriordan Friend
    #463669
    I’m an idiot! My site was offline. When I went back online, I continued to get some error messages but the problem went away gradually in a few minutes.
This topic contains 2 replies, has 1 voice, and was last updated by  jkriordan 12 years, 4 months ago.
