June 15, 2015 at 11:15 am #739086I tried to switch template to a default Joomla template like Beez / Protostar but the problem still persists.
What I did was going to the backend settings of a K2 menu item (K2 / K2 blog style) and assign it to Protostar template style . Then in frontend, it shows 2 pages but with duplicated K2 items. This means that there is something wrong with K2 component on your site.
You can give it a try to see the same.
If possible, take a full backup of your site and re-install K2 component on your site and see how it goes.
June 15, 2015 at 5:15 pm #574119<em>@wvlee 477926 wrote:</em><blockquote>Ok, I was unable to filter by categoery in the back-end so i decided to reinstall K2.
Now i can filter in the back-end, but it made no difference to the front of the site.I deleted the imported content from the old site, and imported the content from joomla articles into K2 . Same Problem
I deleted all the content from K2, made a new categorie and made 22 test articles in K2, still the same issue, it is loading the 10 last articles.
http://www.thefastforum.be/Test/index.php/inhoud</blockquote>
Like i stated: i reinstalec K2 already 🙁
I will do it once agian, and see if there is some data left in the mysqldatabase after I remove the component and before I install it again…June 15, 2015 at 5:15 pm #640458<em>@wvlee 477926 wrote:</em><blockquote>Ok, I was unable to filter by categoery in the back-end so i decided to reinstall K2.
I will do it once agian, and see if there is some data left in the mysqldatabase after I remove the component and before I install it again…June 15, 2015 at 5:15 pm #739133<em>@wvlee 477926 wrote:</em><blockquote>Ok, I was unable to filter by categoery in the back-end so i decided to reinstall K2.
I will do it once agian, and see if there is some data left in the mysqldatabase after I remove the component and before I install it again…Saguaros ModeratorSaguaros
June 16, 2015 at 1:35 am #574140Which version of K2 did you use to re-install? pls try to download again from K2 page.
June 16, 2015 at 1:35 am #640479Which version of K2 did you use to re-install? pls try to download again from K2 page.
June 16, 2015 at 1:35 am #739154Which version of K2 did you use to re-install? pls try to download again from K2 page.
June 17, 2015 at 4:52 pm #574460The latest version from K2 (2.6.9?) was redownloaded and reinstalled and mlade no difference. This was actually one of my first steps.
June 23, 2015 at 8:12 am #575207I’m not sure what’s wrong with your server, please try to download the quickstart package of latest version of this JA Wall template and install into local server to test first and see how it goes.
Then you install again in your hosting server.
June 23, 2015 at 1:20 pm #575240<em>@Saguaros 479669 wrote:</em><blockquote>I’m not sure what’s wrong with your server, please try to download the quickstart package of latest version of this JA Wall template and install into local server to test first and see how it goes.
Then you install again in your hosting server.</blockquote>
Was using a server from hostgator, now another one. it is solved now.
This topic contains 26 replies, has 3 voices, and was last updated by Saguaros 9 years, 5 months ago.
