Viewing 7 posts - 16 through 22 (of 22 total)
  • Saguaros Moderator
    #940310
    Thank you, I can access backend of your site now.
    However, I don’t see JA Wall template installed on your site and I can navigate MegaMenu configuration section in settings of default template on your site easily.
    Could you specify issue you’re facing here so I can help?
    joomlaexcel Friend
    #940445
    Re: " I don’t see JA Wall template installed on your site"
    As I stated in my prior statement – "I deleted the JA Wall Template and Extensions since: 1) I could not get JA Wall to work, and 2) I have been trying to troubleshoot why all my MijoShop shopping cart links are not working."
    I just thought it would take a few seconds to install and see if you could get it to show.
    It has taken nearly 3 weeks just to get to this point… what is the best next step for me or you?
    so could I try to install JA Wall into your site? I need your confirm first.
    joomlaexcel Friend
    #941395
    Yes, you have my permission to install JAWall and any additional ext.needed
    Let me try to install and will get back to you.
    joomlaexcel Friend
    #942279
    Thanks!
    I can reinstall if you prefer
    Ninja Lead Moderator
    #942313
This topic contains 21 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 5 months ago.
