activha Friend
activha
- July 2012
October 10, 2017 at 10:00 pm #1067103Hello
After upgrade to joomla 2.8.1 and K2 2.8.0, JA Wall loads pages without stopping for the k2 user. It seems that the pagination always loads the same page again and again
The code used is
<!-- Pagination --> <?php // Build the additional URL parameters string. $urlparams = ''; if (!empty($this->pagination->_additionalUrlParams)) { foreach ($this->pagination->_additionalUrlParams as $key => $value) { $urlparams .= '&' . $key . '=' . $value; } } $next = $this->pagination->get('pages.current') * $this->pagination->limit; $nextlink = JRoute::_($urlparams . '&' . $this->pagination->prefix . 'limitstart=' . $next); ?> <div id="page-nav"> <a id="page-next-link" href="<?php echo $nextlink ?>"></a> </div>
Seems like the problem comes from wall.js and
/* infinitive scroll for main masonry only */ if ($container.length && $('#page-nav').length && $('#page-next-link').length) { var pathObject = { init: function(){ this.path = ($('#page-next-link').attr('href') || ''); var match = this.path.match(/((page|start)[=-])(\d*)(&*)/i); if(match){ this.type = match[2].toLowerCase(); this.number = match[3]; this.limit = this.type == 'page' ? 1 : this.number; this.number = this.type == 'page' ? this.number : 1; } else { this.type = 'unk'; this.number = 2; this.path = this.path + (this.path.indexOf('?') == -1 ? '?' : '') + 'page='; } }, join: function(page){ if(this.type == 'unk'){ return this.path + this.number++; } else{ return this.path.replace(/((page|start)[=-])(\d*)(&*)/i, '$1' + (this.limit * this.number++) + '$4'); } } };
The joomla pagination object is now :
Joomla\CMS\Pagination\Pagination Object ( [limitstart] => 0 [limit] => 15 [total] => 16 [prefix] => [pagesStart] => 1 [pagesStop] => 2 [pagesCurrent] => 1 [pagesTotal] => 2 [viewall:protected] => [additionalUrlParams:protected] => Array (
So could you have an urgent look and tell me what to change to find the correct behavior back ?
That’s pretty urgent all our users are impacted
Regards Jean
Saguaros ModeratorSaguaros
October 11, 2017 at 9:14 am #1067235Hi Jean,
JA Wall is not ready for J 3.8.1 yet, pls wait for the new release of template before updating Joomla.
activha Friendactivha
- July 2012
October 11, 2017 at 9:17 am #1067236Well that’s too late as we use two different templates on our website and we need also to be secure with 3.8.1
This is the only thing that needs to be solved from our end but I don’t know how to cope with this one.
Can you help me only with this pagination problem and I’ll be glad to wait for the next release of JA Wall for other small corrections ?
That ‘s really important
JeanSaguaros ModeratorSaguaros
October 12, 2017 at 3:17 am #1067414Hi Jean,
I can’t replicate issue at my end, you can share the admin + FTP account of your site so I will take a look.
- July 2012
October 13, 2017 at 5:29 pm #1067824Found the problem, k2 introduced a way to redirect user to home page when there is no items for this user.
As we use pagination on our pages with a virtual domain plugin where the user’s k2 page becomes its own home page, ja wall pagination with this new k2 feature does not work
I had to comment line 410 redirect(JUri::root() in the view.html.php of k2 views/.itemlist/tmpl to solve temporarily the problem
Do you think that you can change ja wall pagination behavior on wall.js to avoid this problem ?
October 16, 2017 at 3:35 am #1068040Could you use that solution at this moment? as I tried to replicate issue but my side but without success: J3.8.1, K2 2.8.0, different pages… but the pagination still work fine.
This topic contains 6 replies, has 2 voices, and was last updated by activha 7 years, 3 months ago.
