Hi all-
I’m getting the same issue with FeedGator not importing content after I’ve deleted everything. I ensured that I deleted the articles and then deleted all Trash. The only way it will re-import is if I create a new feed and then import it that way.
I’ve really done a lot of digging to try to figure this out on my own, but to no luck. Could someone please help out?
Thanks!
Kevin
Wow – so I’ve literally been trying to fix this all day, and just found something the second I posted above. I went to Found Duplicates on FeedGator settings > Synchronize Import Database, and it cleared everything up. Once running the import again, it worked fine. Hope this may help others out.
Just for the record, I was also having the same issue with the Trash not clearing. This article helped me out: http://docs.joomla.org/Fixing_the_assets_table
Thanks,
Kevin
1 user says Thank You to kjlarski for this useful post
This topic contains 17 replies, has 8 voices, and was last updated by kjlarski 11 years, 11 months ago.
