meinlabel Friend
meinlabel
- October 2012
- 2 times in 1 posts
October 28, 2012 at 9:41 am #181769Hello,
i have a problem with the styles. i installed the quickstart package without any problems.
i wanted to activate (or install) the styles and tried to click “discover” and then “install” here:
-> Extension Manager: Discoverbut i got the Error:
JInstaller: :Install: Cannot find Joomla XML setup file
now i cant find the different styles in Template Manager-Styles.
how i can install the styles? i want to use classic or minimalist…best regards
meinlabel Friendmeinlabel
- October 2012
October 28, 2012 at 10:01 am #471296SOLVED! Sorry, didnt read the documentation :/
1 user says Thank You to meinlabel for this useful post
lvogeltanz Friendlvogeltanz
- February 2013
March 17, 2013 at 11:59 am #486729I want install new theme and I do everything step by step with documentation, but I have problem:
i wanted to activate languages and tried to click “discover” and then “install” here:
JInstaller: :Install: Cannot find Joomla XML setup file and below Discover install successful.but Languages create, I can continue as documention. But when I want choose templates theme as image I can choose my theme, but when I save it, default templates theme is back 🙁 What I do wrong? Thanks
Saguaros ModeratorSaguaros
March 18, 2013 at 3:55 am #486783Hi Ivogeltanz,
Could you post your site url here or attach image again since I cannot see the attach image?
Please check the menu assignment in template style you want to display, make sure that it’s assigned to desired page, also try to clean joomla cache after making changes.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by Saguaros 11 years, 10 months ago.
JA Wall Style Problem
