  • Juan Carlos Stauring Friend
    #122362
    Hello 😀
    I have kind of a strange problem. I’m trying to replace images in header:
    /templates/ja_wistery/images/header/sh-01.jpg
    etc. to my own images.
    I have tried FTP the files with no luck >:(;)
    I also tried to change the header folder to 777 to see if that would work but it keeps going back to 755 in any case i’m not able to change the images. Do I have to change the path of the folder in the module? I would prefer not to and keep it the same. Is this not possible :-[
    Best 🙂
    jc
    Menalto Friend
    #228233
    Try to change permission from your hosting panel, or try to upload the images from there
    #228242
    <em>@Menalto 25954 wrote:</em><blockquote>Try to change permission from your hosting panel, or try to upload the images from there</blockquote>
    Yeap, did try but no luck :-[:laugh:;):confused:
    jc
    kashxo Friend
    #228251
    Try this:
    Go to Joomla! Admin Panel, choose Global Configuration >> Server and chmod all folder from there (include old folders) try to change to 755 or 777 and copy images and change back after you’ve copied.
    If not work, try to rename that folder and creat new folder with that old name, then upload images to this new folder.
    #228276
    <em>@kashxo 25977 wrote:</em><blockquote>Try this:
    Go to Joomla! Admin Panel, choose Global Configuration >> Server and chmod all folder from there (include old folders) try to change to 755 or 777 and copy images and change back after you’ve copied.</blockquote>
    :):D:D:laugh:
    That worked, Thank you! 😎
    jc
This topic contains 5 replies, has 3 voices, and was last updated by  Juan Carlos Stauring 17 years, 4 months ago.
