railer Friend
railer
- October 2007
- 24 times in 1 posts
July 18, 2011 at 10:44 pm #166434Hi Joomlart,
I have my JA Zeolite ii template set to a fixed width of 1024 pixels wide.
There are serveral module elements and content that extend over the right edge of the fixed width of the page by about 8 pixels or so.
I’m trying to figure out what elements might be pushing it out over the edge.
Where is the ja-wrapper style located? I can’t find it.
Also, what other styles might be causing this?
Please advise.
Thanks,
railerthangnn1510 Friendthangnn1510
- October 2014
- 278 times in 256 posts
July 19, 2011 at 7:34 am #401790Hi Railer!
Could you give us the site link? We need it to check your problem.
Thank you.
railer Friendrailer
- October 2007
July 21, 2011 at 2:25 pm #402340I figured it out…
Two things:
1. I had commented out line 59 in layout.css:
.column div.ja-moduletable, .column div.moduletable, .column div.ja-module, .column div.module
Uncommenting it solved one problem with a right column module (mod_ixxocart_cart_summary ) that was pushing out past the right edge of my fixed-width template (1024px).
2. In template.css, near line 2441, I set the width of #ja-productwrap to 98.2% to fix a problem with a mod_ixxocart_homepage_products module published in the vm-fp module position that was extending past the right edge of the fixed-width template.
Whew!
Glad that’s done.
Thanks,
railerrailer Friendrailer
- October 2007
August 13, 2011 at 11:47 am #406079Hi thangnn1510,
I am having the same issue with another page in the same site. A module in the right column is extending over the right edge of the page.
I’m sending you a link to it via PM.
Please take a look if you can and let me know what I need to do to resolve it.
Thank you,
Railerrailer Friendrailer
- October 2007
August 13, 2011 at 11:55 am #406083Your PM queue is full so I couldn’t PM you. Link to view problem is (removed).
railer Friendrailer
- October 2007
August 13, 2011 at 11:57 am #406084Actually, this is the link.
URL removed.jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
August 15, 2011 at 5:06 am #406280Hi there
Please try to remove this code
#ja-right .ja-colswrap {
padding-left: 10px;
template.css (line 1692)
Thank you
Viet Vu -
This topic contains 8 replies, has 3 voices, and was last updated by railer 13 years, 4 months ago.
