  • fatfox Friend
    #130511
    Hello, Joomlart,
    I make a website with Ja_Zibal, I use the Char UTF-8 code.
    It works under Firefox perfect, but it can’t show all page under IE 6 or IE 7. So I click View – Encoding – UTF8, then it will be correct.
    My website is here: http://www.yitu.net
    If you click the second menu item (without “auto-select” in IE): 技术档案. It will show you a white page!!!
    http://www.yitu.net/index.php?option=com_content&task=category&sectionid=2&id=2&Itemid=10
    What shall I do?
    #258277
    Hi fatfox !
    Have you fixed the problem ? i have view your site in IE and FF , but don’t find your problem.
    fatfox Friend
    #258289
    hi, hainn84, Thank you for your answer.
    The problem is just in IE. Have you IE6?
    If you didn’t mark [View] – – , then you go to http://www.yitu.net. The first page is Ok, but if you after that click the second menuitem “技术档案”, then you get just a white page.
    In China use the most people IE, so I must fix the problem…:((
    fatfox Friend
    #258293
    IE7 have the same problem as IE6…
    P.S. You shouldn’t mark in beginning the “UTF-8” in Encoding, otherwise, you can’t see the problem too.
    jllamb Friend
    #308001
    In IE6 I get the same problem. All main content is pushed to the bottom and all white space above.
This topic contains 5 replies, has 3 voices, and was last updated by  jllamb 15 years, 6 months ago.
