April 15, 2014 at 12:45 pm #196777
When the instalation of sample data is in progress with quickstart never end, I try many times but not work. Please i need help.
Joomla is triying install sample data about one hour.pavit Moderatorpavit
April 15, 2014 at 3:24 pm #530981Hi
You are installing it on a web space or on your localhost ?
April 15, 2014 at 4:24 pm #530994Hi
On my localhost, i tried to do 10 times. i don´t know what can i do.
I have proven with other templates and not had any problems.
With this template when i push install sample data starts to install but never ends.
April 15, 2014 at 7:11 pm #531008Hi
Just downloaded zite quickstart for Joomla 3.2 and installed on my localhost with xampp it worked like a charm take a look here
- April 16, 2014 at 10:03 am #531109
Now I will try with 3.2 quickstart, I’ve done it with wamp and the quickstart for joomla 2.5.
I’ll try and tell you the result.
April 16, 2014 at 10:38 am #531116I tested with the quickstart zite3.2 in wamp and does not work me. When you finish installing return to the previous screen and not installed.
Please try with wamp and tell me if that’s the problem, i don´t have xamp.
No congratulations message and successfully installed. Automatically returns to the previous screen
Gives this error when installing the sample data and the installation stops
- pavit Moderator
April 16, 2014 at 11:00 am #531118We cannot check your wamp configuration
try to install it on an hosted space to be sure that the quickstart files are corrects and we will check it
April 16, 2014 at 4:42 pm #531142ok i´ll try.
I installed several templates Joomlart and I have not had any problems, only with the sample data ja_zite.
I don´t know what can be. I´ll try to install it on an hosted space and post again.
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by sauftcom 10 years, 5 months ago.
JA zite quickstart sample data not work
