  • woltec Friend
    #166320
    Good morning, then we should start
    Well I have two errors for the same problem, following the common pattern of using localhost using XAMPP got the following error
    JoomlArt has himself indicated the use of WAMP and he does not have the same problem, but I just generates another ending to the installation folder and remove the instalation when I provide the option to access the site or administrator.
    I did both processes through the whole manual I found on the site including video and were not successful.
    #401816
    Hi woltec,
    Please let me know which php & mysql version you are runnning,I might will try to install the quickstart package at my end to see if the problem occurring.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 13 years, 4 months ago.
