November 18, 2009 at 3:12 am #146134
I’m having some trouble on ja_color… on a fresh install of the template without modifications.
1) Setting JA_Color in the admin section correctly changes the color of the template.
Adding ?ja_color=red/blue etc to the URL and the colour does not change.2) I want to access the site from 2x different public domains.
When entering from domain 1, ignore any user cookie and force display of the template in ja_color=blue.
When entering from domain 2, ignore any user cookie and force display of the template in ja_color=red.NOTE: I only want to set this when the user first enters the site… I still want to allow the user to change colour once inside the site.
Sorry I’m not a PHP coder and this is my first Joomla site so I’m still trying to get my head around things but I assume a simple line of code could be added to change the value of ja_color based on the URL.
3) I see in template.css settings for ja-container,-fl, -fr &- f. Does this mean the template can be changed to a fluid layout instead of fixed width? If so how?
Thanks for any help.
PaulAnonymous ModeratorJA Developer
- 2008 times in 1700 posts
November 20, 2009 at 10:24 am #324389Hi geckors4
could you please submit a ticket, send us your live url, admin account so that i could have a closer look on the issue
December 8, 2009 at 4:51 am #325995<em>@geckors4 153452 wrote:</em><blockquote>1) Setting JA_Color in the admin section correctly changes the color of the template.
Adding ?ja_color=red/blue etc to the URL and the colour does not change.</blockquote>Sorted the problem myself…
Setting ?ja_color= in the URL ONLY works when params.ini is NOT writable!zorroson Friendzorroson
- May 2007
- 3 times in 2 posts
January 14, 2010 at 12:03 pm #329295Geckors4,
What is the correct URL for doing this? I tried http://www.domain.com/index.php?ja_color=color and http://www.domain.com/?ja_color=color but to no avail!
No difference if params.ini is writable or not…
Cheers,
Zorroson 😉zorroson Friendzorroson
- May 2007
January 14, 2010 at 12:33 pm #329297Hmm – found this one myself, but cannot believe why Joomlart have not corrected this one?
It turns out, there is a bug in ja_templatetools_15.php where the code is trying to pass variable “usertool_xxx” from the URL – but since this should have been “ja_xxx” ie. “ja_color”, it dosen’t work…
Not my finding though – found it in http://www.joomlart.com/forums/topic/menu-user-color-selection/
But really don’t get why this has not been corrected, as is has been an issue for more than one year…?!/Zorroson
January 16, 2010 at 7:03 am #329444Hi zorroson
For the case, you have to open configuration.php file, add this code to the end of file:
<?php define('_DEMO_MODE_', 1); ?>at that time you can use the link: http://www.domain.com/index.php?ja_color=color
- May 2007
February 3, 2010 at 2:49 pm #331425Whoaaa – touchdown!!!
Thank you, thanx you, thank you – been looking forever for tis!!!! :laugh:
/Zorroson
March 8, 2010 at 2:04 pm #335329It’s getting a silly habbit: download, Install, bugfix.
I just downloaded the template and this error was not fixed. Poor!
- May 2007
March 8, 2010 at 2:08 pm #335330Seems it’s not a bug – you need to include
in configuration.php to enable it…./Zorroson
March 8, 2010 at 2:14 pm #335331ah, so it is a feautre, not a bug. Come on!
It works at the demosite, it should work as well after doing the quick install. I am cleaning up the whole mess which already was reported month ago with this template!
Anyway, I can not find the mentioned “ja_templatetools_15.php” nor the “ja_templatetools_1.5.php” mentioned in the other thread, so I have to modify my configuration.php which may change at any update.
This is not a solution, this is a bugfix!
This topic contains 10 replies, has 4 voices, and was last updated by bitx 14 years, 9 months ago.
