Mustapha Mugisa Friend
Mustapha Mugisa
- April 2014
- 2 times in 2 posts
August 12, 2014 at 6:35 am #200442I have two urgent issues for fixing:
1. Ja fubix fonts are huge after ja updates
2. ja Fubix template has failed to upgrade to newer version. I tried for the past 24 hours without success, i would need help. Error “cannot write files”. I have checked permissions, and they are writable.Please help urgently.
/Mustapha
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
August 13, 2014 at 3:59 am #545775Hi Mustapha,
<blockquote>1. Ja fubix fonts are huge after ja updates</blockquote>
I just checked your site. The “Editor’s Picks” module is working fine.
Have you sorted it out at your end ?
<blockquote>2. ja Fubix template has failed to upgrade to newer version. I tried for the past 24 hours without success, i would need help. Error “cannot write files”. I have checked permissions, and they are writable.</blockquote>
I saw you are using the latest version of JA Fubix template (v1.1.0).
Also, for our JA Extensions, you need to update them via our JAEM component. Pls follow below guide to solve your issue & update our extensions:
http://www.joomlart.com/documentation/wiki-ja-extension-manager/how-to
But make sure that you have configured the JAEM component in the right way first.
http://www.joomlart.com/documentation/wiki-ja-extension-manager/admin-panelLet me know if this helps
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Nazario A 10 years, 4 months ago.
Ja_Fubix "Editors Picks" showing very huge fonts, how to fix
