  • sudheermatta Friend
    #152768
    I am a JA newbie, can you please help me align my website to the center?
    I have tried solutions proposed in other templates and they dont seem to work for me.
    eg: I tried from
    (http://www.joomlart.com/forums/topic/center-everything/
    Here is the best solution to alignt center for the site:
    1) open the file: /templates/ja_lime/css/layout.css
    and find codes:
    HTML Code:
    .main { width: 980px; max-width: 1200px; margin: 0 auto 0 55px; position: relative;}
    and replace:
    HTML Code:
    .main { width: 980px; max-width: 1200px; margin: 0 auto; position: relative;}
    It didnt help.
    Can you please help?
    Live site:
    http://www.asys.us/index.php
    http://www.asys.us direct link doesnt work, since the joomla site is not live yet.
    Thanks,
    John Wesley Brett Moderator
    #350491
    Sudheermatta,
    It appears somehow a CSS setting has been changed.
    Goto: [FONT=”Arial Black”]/templates/ja_halite/css/layout.css – line 29[/FONT]
    Change from this:
    .wrap {
    clear:both;
    width:1024px;
    To this:
    .wrap {
    clear:both;
    width:100%;
    Have fun.
    John.
    smitheringale Friend
    #350497
    I think the simplest way to centre align halite is to do this
    Go to template.css and look for ja-wrapper
    It probably looks something like ja-wrapper { }
    Between the curly brackets, add this
    ja-wrapper {
    margin:auto; CENTRES SITE
    width:981px; THE WIDTH OF THE SITE
    background-color:#ffffff; MAKES THE BACKGROUND OF THE WRAPPER WHITE
    Then look for body bd { }
    This will be in template.css and the css template for the colour you are using, and add a background colour
    body bd {
    background-color:#cccccc; LIGHT GREY
    You might even apply 20px padding to the wrapper to make it have something of a border, in this case, the bit between ja-wrapper would be: –
    ja-wrapper {
    padding:20px; GIVES 20 PIXELS PADDING - LIKE A WHITE BORDER
    <em>@sudheermatta 187278 wrote:</em><blockquote>I am a JA newbie, can you please help me align my website to the center?
    eg: I tried from
    and find codes:
    HTML Code:
    and replace:
    HTML Code:
    It didnt help.
    Live site:
    Thanks,</blockquote>
    sudheermatta Friend
    #350574
    jbrett,
    Thanks very much for the reply. I have a small change to my question. Please help.
    I really meant to ask, how can I restrict my site to be centered, and show up only in the center, and extend side to side. (like the blue area in my site extends from left to right. Instead I want it only show up in the center.
    Eg: I want it to look like http://www.ibm.com or http://www.cisco.com where the site is only restricted in the center.
    Please help. My client like the template, and just wants it restricted to the center. So changing to a different template is not an option for me.
    Thanks much for your time. Really appreciate a response.
    sudheermatta Friend
    #350576
    smitheringle,
    Thank you very much for the reply.
    I tried the changes you suggested. I believe it did align it in the center. Unfortunately like I misarticulated, what I really needed to do is restrict my site to only the center. Like http://www.cisco.com or http://www.ibm.com.
    Can you please help. sincerely appreciate your help.
    Thanks.
    Sudheer
    Laura Rubino Friend
    #350577
    It should have been centered. could you provide a link to your site so i can see just how centered you want it?
    aaronfarias Friend
    #350582
    All the css elements are set to 100% since it is a fluid design. You will have to restrict it to a certain number of pixels.
    sudheermatta Friend
    #350589
    <em>@makegoodmedia 187431 wrote:</em><blockquote>It should have been centered. could you provide a link to your site so i can see just how centered you want it?</blockquote>
    sudheermatta Friend
    #350590
    <em>@aaronfarias 187436 wrote:</em><blockquote>All the css elements are set to 100% since it is a fluid design. You will have to restrict it to a certain number of pixels.</blockquote>
    When I restrict it to 1024px, with
    .wrap {
    clear:both;
    width:1024px;
    The site is coming to 1024px. However, The site is aligning to the left. I want it 1024px width, but align to center.
    Laura Rubino Friend
    #350593
    Go to your layout.css and search for this #ja-mainbody
    remove the float:left;
    #350685
    Hi Sudheermatta,
    I have recently centred a Ja Ores template and it looked just like the IBM website. (EDIT: I thought you were talking about Ores – but what I say below works just as well for halite too – see screenshot as proof)
    What I mentioned above Does work actually (strangely someone rated my suggestion as bad – how weird), but this is my step by step solution – please note that this works from the quickstart only – some other changes you might already have made to the code might interfere with things.
    Finally – I’m going to say the site will be 981 pixels wide as 1024 px is too big for many browsers – not everyone has a big fancy screen 🙂
    1) Go to template.css file and look for
    ja-wrapper { overflow:hidden}
    and change this to
    #ja-wrapper { overflow: hidden; width:981px; margin:auto; padding:15px;background-color:#fff;}
    Then go to the color css – for example, I used a light theme, so I would go to light-theme.css and add change this
    body#bd { color: #353535; background-color: #fff; }
    to this
    body#bd { color: #353535; background-color: #cccccc; }
    You might need to add a background-color or #ccc (grey) to some other color.css files as well depending on what color style you are using.
    If you hate the white padding around the site – remove the padding:15px in the ja-wrapper code above.
    This does work – I’ve just tested it again! (screen shot attached)
    <em>@sudheermatta 187444 wrote:</em><blockquote>When I restrict it to 1024px, with
    .wrap {
    clear:both;
    width:1024px;
    The site is coming to 1024px. However, The site is aligning to the left. I want it 1024px width, but align to center.</blockquote>
    sudheermatta Friend
    #350749
    smitheringale, you are an absolute god send! Thankyou. Thank you. Thankyou.
    Someday I hope to be of some help to you or someone else, at a similar level.
    You have absolutely nailed the issue for me. I cant thank you enough!
    #350753
    I’m still trying to see whether this is a bug or not…or whether there is an enhancement opportunity.
    Why were you not able to accomplish this by simply going to
    EXTENSIONS > TEMPLATE MANAGER > (template) > PARAMETERS > TEMPLATE WIDTH
    Were the “SPECIFIED PIXEL” settings not working?
    Thanks for your help.
    John.
    #350760
    Hi Jbrett,
    Actually, I think that changing the template width in the backend using a specified pixel does work – but it only seems to affect the middle part of the website – the header and footer still stretch for the whole width of the browser window. Thus, even to make it look like a centred site, you have to do something else – and what I outlined above seems to work as well as anything else. My option for using padding rather than a border is for creating a valid site. Having a border colour the same colour as the backgound colour seems to throw up a validation warning (although it still passes). However, I don’t know if this causes problems to browsers not using a technically-correct box model (IE 6 maybe?)
    <em>@jbrett 187660 wrote:</em><blockquote>I’m still trying to see whether this is a bug or not…or whether there is an enhancement opportunity.
    John.</blockquote>
    #350762
    I forgot to mention, that you should make sure the template is set to a specified pixel width of 980px in the http://www.yoursite.com/administrator area.
    choose USE SPECIFIED PIXEL as your option, and type 980 in the box provided. I think it should already have 980px in it.
    <em>@sudheermatta 187655 wrote:</em><blockquote>smitheringale, you are an absolute god send! Thankyou. Thank you. Thankyou.
    You have absolutely nailed the issue for me. I cant thank you enough!</blockquote>
This topic contains 15 replies, has 5 voices, and was last updated by  smitheringale 14 years, 5 months ago.
