gozal Friend
gozal
- June 2006
September 21, 2011 at 8:55 am #168786hello,
I installed the template, and when I connect on my iphone or ipad, I see the layout of the website and not the iphone one. All the parameters are fine in the template .
So how can I do to swith to the iphone layout when using it ?
I install twice the template and it stills doesn’t work. I tried on another website and it works fine. I installed the quickstart file with joomla 1.7.
The only thing I did is to install the french language in the website. I unistall it to check and it’s still the same.
The website is http://www.limpudique.net
Thanks for your help. I chose your template because they are iphone ready so I’m a little bit disapointed.
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
October 9, 2011 at 11:25 am #417909Hi,
This seems to be a late reply, I’m sorry! Can you PM me your admin account and FTP account for further checking?
Viet VuAuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by jooservices 13 years, 2 months ago.
Ja_methys – iphone and ipad problem
