  • creati54 Friend
    #123534
    I am not sure if this has been answered or addressed, so sorry if I’m duplicating a thread… ALSO! This is the first template I’m trying to configure so if this is a REALLY dumb question; forgive me.
    Ok, so I downloaded & installed the JA_Newsflash for Kontiga module. However, I can’t get it to display!? I’m not sure if it’s because the “top” position doesn’t show up on the layout, or what. But how can I get this newsflash to display??
    Here is a link to the site for your reference:
    http://creativeonesdesign.com/CMS
    Thanks SO much in advance 🙂
    Khanh Le Moderator
    #231928
    Please check if you publish the module. Moreover, you need publish the module into position ‘user5’.
    creati54 Friend
    #231955
    Ahh ha, that’s what I needed to know, is what position it was supposed to go in. Thanks so much!
This topic contains 3 replies, has 2 voices, and was last updated by  creati54 17 years, 2 months ago.
