  • vertti2007 Friend
    #121854
    Hey!
    How can I get scandic alphabetics to my ja_newsflash scroller? It is showing textes okay, but when I’m putting ä,ö,å to the title, it is showing only ?-marks in it..?
    Any helps?
    T: Newbie :confused:
    wla_ja Friend
    #227913
    I´ve the same problem with ja_newsflash using mageia. Words with ä, ö, ü, in the title are showan as <?>.
    Tried to replace the titles with htmlcode litke this: Ö
    but it doesn´t work :((
    .. does anyone know how to fix it?
    Cheers Walter
    ministarsrbije82 Friend
    #231115
    <em>@wla_ja 25529 wrote:</em><blockquote>I´ve the same problem with ja_newsflash using mageia. Words with ä, ö, ü, in the title are showan as <?>.
    Cheers Walter</blockquote>
    In /modules/ja_news ther is file headlineloader.php
    Put this string on FIRST LINE (no space form begingi)
    <? header(“Content-Type: text/html; charset=UTF-8”); ?>
    This works if you already use UTF8
This topic contains 3 replies, has 3 voices, and was last updated by  ministarsrbije82 17 years, 1 month ago.
