October 16, 2010 at 9:37 am #155342
JA_Portfolio joomsef and k2 not working together, always load 404. When I change the template with JA_Purity everything works normally. Everything occurs when running a plugin K2 joomsef
Apparently the problem comes from the template, how to solve this problem?
Thanks!Saguaros ModeratorSaguaros
October 19, 2010 at 2:26 am #359469<em>@Face 198825 wrote:</em><blockquote>Hi,
Thanks!</blockquote>HI, can you please provide me the administator account, i would like to check this issue
David Porré FriendDavid Porré
- 9 times in 1 posts
October 20, 2010 at 4:04 pm #359711Hello,
I’m having a problem also with JA_portfolio, K2 and Joomsef.
On my site, the pages load, but the css is not loaded.
I don’t think it’s a htaccess problem, or joomsef problem, because when I change the template everything works fine.Have you found a fix ?
Hoping for answers,
Best regards,
David aka ShapesSaguaros ModeratorSaguaros
October 21, 2010 at 7:11 am #359785Sorry, currently i do not have solution on this, can you please let me know the link to download JoomSef which you are using ? i would like to install it on my site to check this in detail.
October 22, 2010 at 7:53 pm #360157Hello,
here’s a link to your site
http://www.artio.net/joomsef/artio-joomsef-3-xDavid Porré FriendDavid Porré
October 23, 2010 at 9:12 am #360198Hello,
Joomlart support helped me to solve this here.
In admin panel, go to template manager –> Ja Portfolio, there’s a “block” named “css & javascript compress”
select “join & minify” in optimize css and “no” in optimize js.It worked for me, no more problems… 😀
Hope this will help,
Best regards,
David aka ShapesOctober 23, 2010 at 10:15 am #360200I tried this before, but the problem is not solved. Actually there is a problem with all new templates with T3 Framework. Interval that template made by me with T3 Framework, working without any problem
October 23, 2010 at 10:45 am #360203Hi again,
I have Joomsef running alright on Ja Portfolio, Ja Social (with K2, agora, Jomsocial & Virtuemart), Ja Lime, and Ja Ores.
Only Ja Portfolio and Ja Social made me encounter css problems…
I have latest joomsef 3.7.4.
Joomsef created automatically the htaccess file on my server, and I didn’t change it.Here are my configuration screenshots if it can help…
9373Hope this will help,
Best regards,
David aka Shapes
This topic contains 8 replies, has 3 voices, and was last updated by David Porré 14 years, 2 months ago.
