  • njbarbour Friend
    #130580
    I have been looking to use this excellent Template for some time, I finally installed it on two sites I am building and I got the following error message
    Fatal error: Call to a member function getItems() on a non-object in /home/m46336/public_html/check2/templates/ja_purity/ja_menus/Base.class.php on line 30
    Is there something I am missing ?
    I am running Joomla 1.5 on one site and the later 1.5.3 on the other.
    Has anybody come across an issue running the template, the install went without a hitch.
    I would most welcome any pointers you folks may have.
    njb
    Menalto Friend
    #262436
    Did you manage to get this solved?
    If you did please update this post as solved, if not let us know if you still have this problem?
    njbarbour Friend
    #262591
    There is a degree of config to take care of on the main menu page but this is detailed and clear enough.
    Thanks for the help.
    njb
    jfehr Friend
    #302685
    Could you be more specific in what you did to solve this problem? I have exactly the same issue on a new installation Joomla 1.5.10
    jc786 Friend
    #327105
    Can anyone please explain the solution to this problem. It only appears when the horizontal menu is enabled in template config.
    EDIT; i have found a later version of the template which solves the problem of the error message but now i cant seem to see the buttons for te horizontal menu bar. Just one thing after another with this template….
This topic contains 5 replies, has 4 voices, and was last updated by  jc786 15 years ago.
