  • mobimob Friend
    #121357
    This is moved to member section….
    Hi there,
    I use the ja_regulus_ex template but I have a problem with the menu, i’m using the sosmenu(choice 2)
    My placeholders on my menu should only be a placeholder, but somewhere a is inserted instead of only the # on the link. So everytime I click on a placeholder it lead to a # site, instead of just do nothing…
    Could anyone help me, so that I can remove the sign in the menu?
    It must be somewhere in the menuscript?
    Hope to hear from you very soon….everything else is working just fine!
    Best regards,
    Mobimob
    bigrk Friend
    #224094
    You need to post this problem in the JA Regulus Forum in order to get help with your problem.
This topic contains 2 replies, has 2 voices, and was last updated by  bigrk 17 years, 5 months ago.
