  • trusttone Friend
    #129585
    I changed the height parameter for ja_tabs module in Iolite template but it is not having any effect. I am using tabs on the left. Part of my text in the component gets chopped because it does not fit in the default height. Help. Thanks.
    #253200
    Hi trusttone !
    Please send url of your site !
    elandigimedia Friend
    #253539
    Could you provide instructions for this? I wanted to increase the height of my tabs module but no matter what I put it stayed the same.
    Thanks. And by the way, really nice template.
    #253803
    Hi all !
    You can fix this problem by way :
    Open ja_tabs.php file in pluginscontent folder , find following code section at about line 186 :
    if(!isset($params['height']) || $params['height']) $params['height'] = 200;
    change to :
    if(!isset($params['height']) || $params['height']<=0) $params['height'] = 200;
    then We can change height of jatabs module in admin area.
    #253839
    thank you for the tip
    trusttone Friend
    #254450
    Hi elandigimedia,
    Thanks for the solution.
    Trusttone
    dig814 Friend
    #257872
    Thanks Much for that tip. Should be a sticky as others will run into that problem. I have a question. I am usinf lolite and pulling in articles for JA Tabs. Now that I got the height figuged out, it works well other than the read more doesn’t show up. Is it supposed to? How can I get that to show?
    parpar Friend
    #259178
    thank you, works great
This topic contains 8 replies, has 5 voices, and was last updated by  parpar 16 years, 5 months ago.
