  • hegge Friend
    #148742
    Is it possible to put JA_tabs into one page of the body section? If yes, how do i do that?
    Thanks!
    Arthur
    Yes it possible.
    The ja tab has two extesions: ja tabs plugin and ja tabs module.
    pls following to the userguide http://www.joomlart.com/forums/topic/ja-tabs-userguide/
    Good luck
    hegge Friend
    #335130
    Hi Tienhc,
    I have made several articles and like to use the tab function in one article so that the tabs function apaears in the body section of this artcile only. I can’t figure it out when i’m following the userguide. Can you give me some more info?
    Thanks!
    Arthur
    Dear Arthur!
    May be you forgot turn on the JA Tabs Module: here is the example:
    {jatabs type=”content” position=”top” height=”auto” mouseType=”click” animType=”animMoveHor” }
    TAB CONTENT OF Feature”]
    TAB CONTENT OF Feature 2″]
    TAB CONTENT OF Feature 3″]
    {/jatabs}
    pls put them into a article and try to check this
    hegge Friend
    #335432
    Sometimes the solution is much more simple than expected! Thanks!
This topic contains 5 replies, has 2 voices, and was last updated by  hegge 14 years, 9 months ago.
