  • antonio forte Friend
    #150127
    Hello Guy, I have a problem with Ja_tabs. If I activete plugin and module, than the output that I receive on the frontend of my web site is:
    {jatabs type=”modules” animType=”animFade” style=”default” position=”top” widthTabs=”120″ heightTabs=”30″ width=”100%” height=”auto” mouseType=”click” duration=”1000″ colors=”10″ module=”ja-tabs” }{/jatabs}
    What’s the meaning of?
    Tnx You
    Dear cyber81!
    Pls turn on the ja tabs plugin to resolve this issue
    Good luck
    #339200
    Hello but I have activated ja_tabs plugin but I have the same error
    Dear cyber81!
    Can you pls give us the link to your site and the administrator account, we’ll try to resolve this
    #339724
    <em>@tienhc 173653 wrote:</em><blockquote>Dear cyber81!
    Thanks</blockquote>
    I have send a Private Message to you!
    filmlover7 Friend
    #339790
    <em>@cyber81 173020 wrote:</em><blockquote>Hello Guy, I have a problem with Ja_tabs. If I activete plugin and module, than the output that I receive on the frontend of my web site is:
    Tnx You</blockquote>
    I have the same problem. http://www.j.reflectionson.us
    What is the function of JA Tabs … and other Tabs used in Teline for that matter.
    did you fix your site?
    Dear all
    here is the solution to resolve this issue
    http://www.joomlart.com/forums/showthread.php?p=173897#post173897
    pmorisseau Friend
    #457425
    Hi Saguaros
    I have the same issue with the Tab plugin acting up ….
    i explore the fix that you proposed and i can’t find the exact path where the file “ja_tabs.php” is located.
    please advice if there is another fix for this issue
    I m using joomla 2.5
    Here a link to the site: http://langkreyol.com/vide/
    1. tabs-issues
    Hi pmorisseau,
    PM me admin and FTP account, I shall check this for you.
    pmorisseau Friend
    #457609
    <em>@Saguaros 325506 wrote:</em><blockquote>Hi pmorisseau,
    PM me admin and FTP account, I shall check this for you.</blockquote>
    Hi Saguaros
    I PM you the information that you requested about the ftp and password
    Please advice once done
    Pmorisseau
    pmorisseau Friend
    #458086
    I’ m still waiting on a feedback from Saguaros
    can somebody else step in to help
    That will be very much appreciated
    Pmorisseau
    <em>@pmorisseau 325619 wrote:</em><blockquote>Hi Saguaros
    Pmorisseau</blockquote>
    Hi pmorisseau,
    The problem comes from the loading priority of JA Tabs and JA Popup plugins, I change order of these 2 plugins and it’s fine now.
    Please have a check and confirm.
This topic contains 12 replies, has 4 voices, and was last updated by  Saguaros 12 years, 6 months ago.
