  • stavr Friend
    #142262
    Hello everybody
    I’m trying to set up my first website in joomla and i would like to show the “characteristics” and “the technical features”, as 2 tabs inside the body area.
    I’m sorry I dont have a demo to show you because I’m working on my PC. I haven’t made any moderations to the JA_Nickel template and I have the 1.5.11 version.
    Is it possible to show the category layout with tabs? Or is there any chance to insert tab module in body area.
    Thank you in advance
    Anonymous Moderator
    #309513
    For the question: Or is there any chance to insert tab module in body area.
    => You can enable Content – Load Module plugin and use {loadposition your_position} for your issue
This topic contains 2 replies, has 2 voices, and was last updated by Anonymous 15 years, 4 months ago.
