Viewing 15 posts - 16 through 30 (of 38 total)
  • steinar Friend
    #440688
    <em>@waelali 303660 wrote:</em><blockquote>The attached image explains the problem.</blockquote>
    Hi waelali,
    Have you updated the template and modules etc yet? It isn’t very productive to struggle with a beta version from 2010, you know. 🙂
    waelali Friend
    #440699
    No did not update it yet …
    I am afraid to loose all my customization..
    How did you know it is beta version from 2010??
    How to make these updates??? 🙂 So I can do them
    Phill Moderator
    #440700
    As said earlier, install Akeeba Backup – https://www.akeebabackup.com/
    The do a backup of your site.
    Do you have WAMP installed on your local machine? If so take that backup and with a couple of clicks using the kickstart.php file from the akeeba site you can have an exact copy of your live site running on your desktop.
    On your desktop you can then use the JA Extension manager to update all of your plugins, components, modules and the template one by one safe in the knowledge that you will do no harm to your live site. If all goes well you can copy your now updated site to your live hosting.
    waelali Friend
    #440701
    <em>@phill luckhurst 303704 wrote:</em><blockquote>As said earlier, install Akeeba Backup – https://www.akeebabackup.com/
    On your desktop you can then use the JA Extension manager to update all of your plugins, components, modules and the template one by one safe in the knowledge that you will do no harm to your live site. If all goes well you can copy your now updated site to your live hosting.</blockquote>
    Thank you my friend. I will do that and then we w ill see what happens. I appreciate your help. 🙂
    steinar Friend
    #440717
    <em>@waelali 303702 wrote:</em><blockquote>I am afraid to loose all my customization..
    How did you know it is beta version from 2010??</blockquote>
    Hi again,
    I sent you a private message earlier today. Didn’t you get it?
    Go to Components >> JA Extension Manager >> Service >> Joomlart Updates >> Edit
    and add your JoomlArt username and (if required) your JoomlArt password. Then click Check Update under each of the JA elements and take it from there.
    The procedure is pretty close to risk free and you won’t lose your customization. But it is of course prudent to make sure you have a backup; follow Phill’s advice.
    waelali Friend
    #440718
    <em>@steinar 303722 wrote:</em><blockquote>Hi again,
    :)</blockquote>
    I will check if I got it 🙂
    waelali Friend
    #440722
    What about JoomlaWork modules and extensions?? there is alot of them there 🙂
    Phill Moderator
    #440729
    What about them? If you are goint to J2.5 then you would need to migrate and install new versions. If you are just upgrading to the latest release of J1.5 and all the JA extensions then they would not be a problem.
    steinar Friend
    #440730
    <em>@waelali 303727 wrote:</em><blockquote>What about JoomlaWork modules and extensions?? there is alot of them there :-)</blockquote>
    Don’t let them hinder your update of the template and JoomlArt modules and plugins. But you will need to download the newest 1.5 versions from their different creators and install them from your desktop. As long as you stay inside the scope of Joomla! 1.5 there isn’t much to fear from the update process.
    Edit: Phill beat me to it 🙂
    waelali Friend
    #440731
    Thanks 🙂
    I am updating
    steinar Friend
    #440733
    <em>@waelali 303737 wrote:</em><blockquote>I am updating</blockquote>
    Breathlessly awaiting your report …
    Phill Moderator
    #440736
    Waelali,
    Hope you do not mind, I have taken the liberty of backing up your site just in case.
    waelali Friend
    #440737
    I am updating directly on the online site after backuping , however the template is not upgrading 🙁 I am still trying
    I am into the process of the template – but still in process forever 🙁
    waelali Friend
    #440738
    <em>@phill luckhurst 303742 wrote:</em><blockquote>Waelali,
    Hope you do not mind, I have taken the liberty of backing up your site just in case.</blockquote>
    It is ok – however I did that also 🙂
    Phill Moderator
    #440739
    Check the file permissions in your templates directory.
    Oh, you are also going to need to update your Joomla install via ftp with this download – http://joomlacode.org/gf/download/frsrelease/16025/69668/Joomla_1.5.0_to_1.5.25-Stable-Patch_Package.zip
This topic contains 38 replies, has 3 voices, and was last updated by  waelali 12 years, 10 months ago.
