  • easykey Friend
    #138931
    Upgraded site to Joomla 1.5.9 and VM 1.1.2
    Using the JoomlArt template for the category called ja_vm_cat_browse with 2 columns.
    I have noticed that strange things have happened to the position of products – they don’t line up properly and there used to be a vertical dotted line between all products and a horizontal doted line between rows. This worked beaytifully in the earlier version but has even more problems in Firefox.
    See link below to view the problem
    http://www.offthewallsports.co.uk/index.php?page=shop.browse&category_id=1&option=com_virtuemart&Itemid=64
    nathanbohn Friend
    #295048
    what versions did you upgrade from? check with virtuemart to see if there was something that changed? it seems like the hr’s in span.ja-separator are getting called incorrectly, obviously in the upgrade.
This topic contains 2 replies, has 2 voices, and was last updated by  nathanbohn 15 years, 9 months ago.
