  • marcelke Friend
    #170304
    I am using JA Ores with Joomla 1.5 and JACL Pro (from Byostech) for the ACL. I notice that the access levels created with JACL PRO do not work in the mainmenu on the menu position. (The standard Joomla access levels do work).
    From a Yootheme template I know that they made a modification in yoomenu.php the template/html/mod_mainmenu directory. See the modification code below. Probably something like this should be done in a file of the JA Ores template. But which one?
    [PHP]if ($node->name() == ‘ul’) {
    foreach ($node->children() as $child)
    // Start JACLPlus Modification
    if( defined(‘_JACL’) ) {
    if (!JACLPlus::inList($child->attributes(‘access’), $user->get(‘jaclplus’, ‘0’))) {
    $node->removeChild($child);
    } else
    // End JACLPlus Modification
    if ($child->attributes(‘access’) > $user->get(‘aid’, 0)) {
    [/PHP]
    If some ones can help met with? Are there others who have the same problem?
    Kind regards,
    Marcel
    marcelke Friend
    #423585
    In the meantime at Byostech they are working on it.
This topic contains 2 replies, has 1 voice, and was last updated by  marcelke 13 years ago.
