  • Jeancarlos Rodriguez Friend
    #1063611
    If I’m not using the builder and I want to the regular JACM module, When i go to Module —> New and select block type…..I only have access to a few JACM module block types like the following:
    Accordion
    Call to Action
    Intro Features ( i only have 2 features)
    Slide show
    Teams
    I dont have all the JACM Block type. When i use another template and create a new module i have more selection when using JACM module.
    Pankaj Sharma Moderator
    #1063763
    JA ACM module has different ACM style file for the different template.
    For Example, JA Mood template has only one ACM style. Each ACM style is defined for the template specific.
    If you want to use other templates ACM style you can follow this documentation.
    #1064005
    Do we only need to upload the uber/acm directory or way other file do we need to install?
    Do i install JA ACM 2.1.2? or
    JA ACM 2.1.3
    The uber package has the JA ACM 2.1.2 package.
    Also do i need to install any files or directory for the positions to work?
    Please let me know.
    #1064059
    First, update the JA ACM module to latest version.
    Now if you want to import the ACM style block from uber template you need to copy that acm files or folder in your JA Company template.
    Make sure the style of these ACM will support for uber template, In this template, you need to apply some style to custom.css file using firebug or inspect element.
    For more infor please check the documentation I shared in the last post.
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 2 months ago.
