  • jferrercas Friend
    #137405
    I have a problem with janews in the homepage of http://dev.bosquetheravada.org/
    Font tools are not showed with IE6 and IE6 shows a javascript error. In the other pages there are no problem.
    IE7 and Mozilla show font tools, but they don´t do nothing in homepage. They work ok in other pages.
    If I disable janews module there is no problem in homepage.
    I attach the error in IE6 . 4102
    Please, can you help me?
    1. error
    jferrercas Friend
    #288452
    I reinstalled the template and extensions and everything was OK.
    But I made some modifications (see picture) to separate columns with dots and some modifications for the janews links.
    Now the problem is with Internet Explorer 6. In configuration of JNews 1.3.1 If Intro Items=1 no problem but If Intro Items is more than one there is a problem with columns.
    See atached files:
    With Intro Items=1 everithing OK (see col1.jpg)
    With Intro Items=2 columns error. The second colum stars when the first column ends (see col2.jpg and col3.jpg)
    Please, any help?
    1. col1
    2. col2
    3. col3
    jferrercas Friend
    #288606
    If I select a module (i.e. User Access) in right position everything is OK. But the cuestion is that i don´t want this.
    I think it is a bug in janews. Ja_Rutile typical configuration has a left column and a right column, but if you don´t use them there is an error.
    Please, support. I paid for the template but it does not work ok!
    #289483
    Dear jferrercas !
    Please try to fix it following way below :
    Open blog.php file in modulesmod_janewstmpl folder , find following code section at about line 32 :
    $width = 99.9/$cols;
    change to :
    $width = 98.9/$cols;
    jferrercas Friend
    #289737
    Thank you very much for your response! Now everything is OK.
This topic contains 5 replies, has 2 voices, and was last updated by  jferrercas 15 years, 11 months ago.
