December 8, 2009 at 11:24 am #146688
Hi, i’m new here. I have some problem with janews2 in Internet explorer 7.0 or more. Firefox Mozilla is ok everything, but with IE i have some problem with janews2. Somebody can help me?
the site is http://www.laltraagrigento.it
Another question: i have Jateline III beta versione (test), now how can i recharge new jateline III in my ftp without delete all article and all features that i upload in my site??
Thank you for help.
kryptos Friendkryptos
- November 2009
- 13 times in 9 posts
December 8, 2009 at 11:58 am #326044December 8, 2009 at 1:01 pm #326049Thank you friend but nothing, again problems on internet explorer with jateline III
in firefox mozilla is all ok, in IE have problems. i try to stop module janews2 and the rest of site go best….but without janews2 the site is very bad to look!!
somebody can resolve my problem ?
- November 2009
December 8, 2009 at 1:16 pm #326050This is an error which I get in my IE browser:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Tue, 8 Dec 2009 22:10:05 UTCMessage: Syntax error
Line: 359
Char: 1
Code: 0
URI: http://www.laltraagrigento.it/line no 359 is beggining of google search ad script, try to disable it or banner under it…
anyway, try to disable all modules and reanable them again one by one until you see which one make this problem..
good luck…
December 8, 2009 at 1:57 pm #326052<em>@kryptos 156088 wrote:</em><blockquote>This is an error which I get in my IE browser:
Line: 359
Char: 1
Code: 0
good luck…</blockquote>
thank you, i try, no active all google ads, but error in IE continue… my god!!!
and other problem is this: in FIREFOX MOZILLA this link is ok
http://www.laltraagrigento.it/index.php?option=com_content&view=category&layout=blog&id=82&Itemid=459In Internet Explorer is not correct!!!
Somebody can help me? thank you
micrantha Friendmicrantha
- May 2007
- 158 times in 148 posts
December 8, 2009 at 3:34 pm #326062May be you should clean up some of your page code.
When I open your homepage and look into sourcecode of page I read lines like these:
(this in in article “Piero Luparello e il futuro del Partito Democratico“)
<xml>
<w:WordDocument>
<w:View>
Normal
</w:View>
<w:Zoom>
0
<w:HyphenationZone>
14
</w:HyphenationZone>
<w:PunctuationKerning />
<w:ValidateAgainstSchemas />
<w:SaveIfXMLInvalid>
false
</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>
false
</w:IgnoreMixedContent>
................etc.
Probably content not pasted as plain text.
Hope it helps you.
1 user says Thank You to micrantha for this useful post
December 8, 2009 at 4:07 pm #326065yes but with firefox it’s all ok, but with IE i continue to have problem
for you this code in this article can be a error for janews2 module in IE ?
i tryng your suggest: i resole something but not all, i have again problem in homepage, but in other i resolve. thank you.
have some suggest for problem in homepage dont’ work in IE ??
- May 2007
December 8, 2009 at 4:31 pm #326066Hello pachitos,
In my experience only 1 article with this kind of code was enough to break the page in IE-browsers in the same way, while in Firefox and Safari no problem!
So I advice you to clean the code of these articles, or unpublish them as experiment, and see what happens with your page when you only have clean articles.
Succes, Micrantha
December 8, 2009 at 4:39 pm #326067yo u are the best, man! i resolve.. only one problem i have just now: not look first menu in janews2: the POLITICA
thank you again
- May 2007
December 8, 2009 at 4:44 pm #326068Hello,
I am not quite understanding what you ask: what is exactly the problem?
O sorry, I see: you mean it is not there at all in IE!micrantha Friendmicrantha
- May 2007
December 8, 2009 at 5:01 pm #326070Hello,
Just look in source code of homepage in IE:
The Section POLITICA is there, but again you can find code like:<p class="MsoNormal">
<span style="font-size: 10pt; font-family: Arial;">
Piero Luparello fa parte dell’esecutivo regionale...<p class="MsoNormal" style="text-align: justify;">
<span style="font-family: Arial;">
<em>
La scomparsa di Patò
</em>
L'hanno piazzata nel bel mezzo del centro urbano d...
</p>
Antipatico. Stava davvero antipatico. A destra e a...
Perhaps all will change when you clean this up too.
Hope so for you,Greetings,
Micrantha1 user says Thank You to micrantha for this useful post
December 8, 2009 at 6:54 pm #326077Many thanks my friend.
You have again reason!!! are very a perfect suggest and very joomla expert.
Only another: in IE (!!) i look this error: error motools code 3605 and 1904 line. must I change my mootols? Must Update?
Thank you!
Kind Regards
- May 2007
December 8, 2009 at 8:50 pm #326084Congratulations so far.
What version of Joomla do you use?
The errors point to core Joomla fileline: 1904
character: 10
URI: http://www.laltraagrigento.it/media/system/js/mootools.jsline: 3605
character: 4
Code: 0
URI: http://www.laltraagrigento.it/media/system/js/mootools.jsSo you could update js-file or complete Joomla-version if needed.
Anyway, IE now shows page correct I think.kryptos Friendkryptos
- November 2009
December 8, 2009 at 9:04 pm #326088<em>@micrantha 156132 wrote:</em><blockquote>
Anyway, IE now shows page correct I think.</blockquote>unfortunately, not for me 🙁
still a lot of errors, and when page finally loads, I see modules now, and IE6 warning although I have IE8..
I think you right, he should upgrade joomla or mootools…
I had the same issue, but problem was in one module… sometimes it just woun’t work with this template.. :confused:
This topic contains 29 replies, has 3 voices, and was last updated by pachitos 15 years ago.
