Viewing 14 posts - 16 through 29 (of 29 total)
  • pachitos Friend
    #326090
    i use 1.5.14 joomla version and now go to upload in 1.5.15
    thanks again
    a question: for you my site works in all IE version? i test only in IE8
    kryptos Friend
    #326091
    pachitos Friend
    #326092
    Sorry kriptos i ask the last question:
    I Upload 1.5.15 joomla but IE find again a error of mootools…i ask: is important for you this error??
    for me the site is all ok!!
    micrantha Friend
    #326093
    I can also enjoy your site in IE7; it seems OK there.
    But you can add special code for IE8.
    See my post
    http://www.joomlart.com/forums/showpost.php?p=155367&postcount=2
    Maybe again a step forward to final solution.
    kryptos Friend
    #326094
    I don’t know wuy, but I still got many errors when I try to open your page. try disable janews2 module to see if it produce this error…
    1. untitled
    2. untitled2
    micrantha Friend
    #326099
    I have no idea how to go on.
    Homeage looks OK, but Indeed I see in left corner message that page contains errors, in fact quite a list.
    f.i in ja_teline_iii/js/ja.ddmod.js, line 373, character 5: ‘_p.id’ is empty???
    Google Chrome OK, Safari OK……IE crazy?
    kryptos Friend
    #326100
    that’s what I’m telling you… it seems ok, but errors are still there…
    ja.ddmod.js is part of janews2.module in template directory, I think it is script for moving janews2 module up and down. he need to upgrade template on 1.3 version.
    micrantha Friend
    #326105
    It seems user thongtinhanquoc had(s) same problem:
    http://www.joomlart.com/forums/showpost.php?p=154929&postcount=1
    also this line 373 in ja.ddmod.js
    tienhc from J.O.O.M Staff promises to fix it, but solution not published in that thread.
    Maybe pachitos can ask staff.
    micrantha Friend
    #326106
    One last attempt:
    When debugging in Firefox I see 80(!) errors.
    I have attached file with report.
    Maybe this generates other issues.
    pachitos Friend
    #326107
    MY GOD!! 80 errors??? i must update 1.3 ? but not is dangerous for my site sure?
    micrantha Friend
    #326108
    Don’t be afraid of 80 errors: many are in the same lines.
    Many are in a-tags like < a alt=” ” “>; so incorrect use of “: use them only for beginning and end of text-string.
    Many are simple: not closing <p> or not opening </p>.
    And before updating to 1.3: first backup your site.
    pachitos Friend
    #326109
    <em>@micrantha 156152 wrote:</em><blockquote>I have no idea how to go on.
    Google Chrome OK, Safari OK……IE crazy?</blockquote>
    this look in ddmod al line 373
    c += el._p.id + "_" + el._h.getText().trim().substr(0,20) + "_" + i + "_" + (el._h.className.test('hide')?'hide':'show')+",";
    },this);
    micrantha Friend
    #326110
    Yes, but in my site this same code gives no problem. So I think it gives problems in your site because of many code-errors. Like I wrote above.
    You also often use title-attributes like titel=”tekst”text””.
    Then there are lines where you open with <p> and close with</div>.
    So: it is worth trying the path of first debugging these lines. then see if problem persists.
    I am closing. Next day I will see if you got succes.
    Best regards, Micrantha
    pachitos Friend
    #326116
    <em>@micrantha 156163 wrote:</em><blockquote>Yes, but in my site this same code gives no problem. So I think it gives problems in your site because of many code-errors. Like I wrote above.
    Best regards, Micrantha</blockquote>
    Very thanks micrantha for all time that you lose for me today. Good night.
This topic contains 29 replies, has 3 voices, and was last updated by  pachitos 15 years ago.
