  • smartmax Friend
    #178758
    Sorry to be such a burden, but my website is almost finished, I have to presentate the site this friday to my cliënt.
    And there are 3 minor problems and I really need your help;
    1. In JASlideshow the text doesn’t correspondate with the picture? (frontpage)
    this looks a little bit strange
    2. In JABulletin the images don’t show? (frontpage)
    3. Is there a way to not to link to an article, but to a specific ‘catagoryblog’ in JAContentSlider? (frontpage)
    for example: “Bedrijven” to: http://www.matestrainingen.nl/index.php/bedrijven
    and “Retail” to: http://www.matestrainingen.nl/index.php/retail
    Many Thanks in Advance! :-[
    HeR0 Friend
    #459856
    Hi Smartmax
    1. In JASlideshow the text doesn’t correspondate with the picture? (frontpage) , this looks a little bit strange
    => I clean cache then the module work well
    => Please upgrade to latest version
    => I change the setting to html link. Are you ok?
    Regards,
    smartmax Friend
    #459880
    Hi HeR0,
    Many, many thanks voor answering number 1 and 2, and it worked, i am happy!
    But 3: I don’t understand (sorry) – I am oké 🙂
    but what I would like to see in JACONTENTSLIDER ‘Wat wij doen
    when you click on ‘Bedrijven‘ – you go to: http://www.matestrainingen.nl/bedrijven.html
    Best Regards
    1. Afbeelding-1
    HeR0 Friend
    #459929
    Hi Smartmax,
    In case 3, i only change setting global configuration. I enable html ( include friendly link and html link type ) link type instead of only friendly link.
    Regards,
    smartmax Friend
    #460068
    Hi HeR0,
    I am very sorry, but I still don’t understand?
    The problem isn’t solved yet…
    Best Regards
    HeR0 Friend
    #460191
    It’s the link sef method.
    If you want to customize the displayed link, you must modify it in the router.php file in com_content or you can use a sef components as sh404sef, artio,….
    Regards,
    smartmax Friend
    #461275
    Dear HeR0,
    My client wanted to remove the CONTENTSLIDER than, but make de SLIDESHOW bigger/higher. It is set to 235 px high.
    How can I make it look like the demo again? Like in a frame-look?? I seem to be missing something at the bottom? Please need your help…
    1. Afbeelding-1kopie
    HeR0 Friend
    #461279
    Please open /modules/mod_jaslideshow/assets/themes/community/mod_jaslideshow.css file then
    Find
    #ja-slideshow .ja-slide-mask, #ja-slideshow .ja-slide-mask2 {
    background: url(“images/mask-l.png”) no-repeat scroll left top transparent;
    display: block;
    height: 215px;
    position: absolute;
    top: 0;
    width: 40px;
    z-index: 2;
    And change height: 215px; to height: 235px;
    Hope that can help you
    Regards,
    smartmax Friend
    #461290
    Great Thanks, But almost! Still need de bottom purple line…(?) so it will look like a frame…
    HeR0 Friend
    #461296
    Hi Smartmax
    Sorry, you should do it by yourself 🙂 , because you changed all design color of slideshow with our demo. So i can not take it .
    Regards,
This topic contains 10 replies, has 2 voices, and was last updated by  HeR0 12 years, 5 months ago.
