July 8, 2014 at 8:56 am #199510
Hy, I’m trying to extend slideshow text horizontally, but I can not save changes to the css file indicated but recharge every time the text in a different way from how I would set. I also tried to add the reference classes in my custom.css. What I’m doing wrong and how can I solve this problem?
Thank youPankaj Sharma ModeratorPankaj Sharma
July 8, 2014 at 10:56 am #541534OK here is the screenshot
I need to enlarge and center this text entered in the module configuration panel. I tried to edit the css files but can not save changes.
Thank for your help
July 8, 2014 at 10:58 am #541535I’m sorry I forgot the url: http://www.rimog.com/index.php
July 8, 2014 at 11:16 am #541537<em>@rutilla 435680 wrote:</em><blockquote>OK here is the screenshot
I need to enlarge and center this text entered in the module configuration panel. I tried to edit the css files but can not save changes.</blockquote>
Hello rutilla , as i can see you are using custom animation that is designed for image +text .
And you are using text on a background image .
Please select class downdown for the above image .
If you have facing any issue .PM me admin details of your site , i will change it and let you know about the changes .Pankaj Sharma ModeratorPankaj Sharma
July 8, 2014 at 11:16 am #541538<em>@rutilla 435680 wrote:</em><blockquote>OK here is the screenshot
Please select class downdown for the above image .If you have facing any issue .PM me admin details of your site , i will change it and let you know about the changes .
July 8, 2014 at 2:37 pm #541563Thank you very much!!! It seems to work right 😀
July 12, 2014 at 7:17 am #542079Dear friends
my site load very slowly I check it in “http://www.pagescoring.com/”, it load about 25 Seconds,I search forum and find this solution that works for me:
turn off develop mode,
turn on Optimize CSS,
turn on Optimize js,
set JS Compress Tool to JSMin,when check again in “http://www.pagescoring.com/”, it load about 4 Seconds,
now in responsive mode, all slide on slideshow will show following, when I use the develop mode in theme, slideshow will working fine but site load very slowly.
I use slide type in slideshow module, with 6 slides.when I use the custom css type in slideshow module, in responsive mode all the text and image will be tumultuous.
slideshow tottaly have problem in responsive mode.
what should I do for solving this ?Pankaj Sharma ModeratorPankaj Sharma
July 12, 2014 at 7:24 am #542080Hello …
Optimization Css and Js is making the site Faster, it will minify your css and Js .
For the issue related to Slideshow i requested you to please open a new thread . and add a screenshot illustrate your problem in it.
New peoblem a new thread .. 🙂
We will help you there.July 13, 2014 at 7:00 am #542128ok, I will.
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 3 voices, and was last updated by noorantel 10 years, 3 months ago.
