freefall Friend
freefall
- December 2007
November 1, 2008 at 12:05 am #134966It looked fine first then all of sudden transparent text box background on Bottom-Right side is not square any more on joomlart Demo site (IE7).
Is there a solution for this? Thank you.
1 user says Thank You to freefall for this useful post
lindskog Friendlindskog
- November 2008
November 2, 2008 at 10:58 am #277764I notice this too in ie7 – the above image shows it more clearly with the white bg – it is jagged and not just in the corner.
Also ie spaces the thumbnails further apart than FF – anyway to change that?
My example above is the J1.5 version.
November 2, 2008 at 11:04 am #277765Yes, I ‘m getting the same too … :((
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 3 voices, and was last updated by slowsteady 16 years ago.
