timeoutcorner Friend
timeoutcorner
- April 2014
August 17, 2014 at 12:18 am #200568I am not sure what is wrong but when I am using Chrome, IE, or Opera the left side menu acts really strange when hovering over the icons, all of the text and links somehow start overlapping each other and are out of place. This started happening after a few days when no work was done on the site. I am not sure why it is doing this as it works perfectly fine when using FireFox.
Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
August 18, 2014 at 9:16 am #546328This bug comes from our template. We will fix this bug and release in the next version. For now, here is solution for you:
– Open file: /templates/ja_smashboard/less/navigation.less then find and remove this code : (line 81)
.transition(opacity 0.35s ease-out);
– Go to the template manager and press “LESS to CSS” button then check your site again. (Remember to BACKUP all current css files first as when compiling less to css, they will be overridden)
Let me know if this helps
1 user says Thank You to Nazario A for this useful post
timeoutcorner Friendtimeoutcorner
- April 2014
August 18, 2014 at 6:21 pm #546429That worked thanks for the help.
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by timeoutcorner 10 years, 4 months ago.
JaSmashboard scrolling issue using Chrome, Explorer, and Opera
