  • Hans Zuidinga Friend
    #182063
    I tried to built a multi language site for the shop where I work.
    The extensions used are:
    Virtuemart
    K2 and K2Mart
    Offlajn K2 Menu
    One Page Checkout
    ACL Manager
    And the blank JAT3V2, which is my favorite for quite some time.
    The MegaMenu has only one home page in every language.
    The signals are saying that everything is ok, but it is not.
    This is the new site http://www.fotolooman.nl/fotolooman_nieuw_ml/
    Advice and tips are welkom.
    Thanks for your time.
    Luna Garden Moderator
    #472367
    Hi, to make menu for each Languages, please copy template don’t duplicate.
    Go to backend >> Extension >> Template Manager >> Click on Tab Templates >> Choose the blank JAT3v2 template >> In new page, on Copy template, fill the input box and copy template.
    You back to Template Manager >> Style: there you will have new template >> Assign language for this template, and change Menu type (tab Profiles) for it (base on what language this style displays)
    Hope this helps.
    #472406
    Thanks for your reply.
    I already did it. Was posted on a thread on this forum. 😎
    To get this result?
    On several pages the mega menu disappears.
    Strange/Unexpected/Unwanted behavior.
    Everyday coming closer to the solution.
    1. languages
    #472464
    <em>@eclecticus 345514 wrote:</em><blockquote>Thanks for your reply.
    To get this result?
    Everyday coming closer to the solution.</blockquote>
    The problem is – you only set template for one menu but not to all pages.
    I have go to back-end template and fix for each template of each languages.
    I think your site is fine now.
    #472494
    Great!
    Ok, I was thinking in that direction.
    You did it.
    Marvelous.
    Thanks a lot.
    #472545
    A question came up.
    When I alter the template.css where should I upload it?
    The all template or per language?
    Thanks,
    Hans
    #472587
    <em>@eclecticus 345707 wrote:</em><blockquote>A question came up.
    Thanks,
    Hans</blockquote>
    Yes,
    You have to update for each template, as you see in folder ‘templates/’, there’s 4 folders template for En, Fr, Nl, and De.
This topic contains 7 replies, has 2 voices, and was last updated by  Luna Garden 12 years ago.
