test melih
 melih
  • aaberg Friend
    #870187
    Hi!
    I have installed and used JA_Methys for about 1 year on a website http://www.bccc.se but I on and off get problems with JAT3 cache that make it impossible to send any forms from Form maker, that I use on the sites. After I have cleaned JAT3 cache it works fine again for a while. Then I get this error again and have to clean JAT3 cache. Cache in gobal settings are off and I use Joomla 3.4.8.
    I also have problem that I have can see in Joomla that I need to update following, but then I click "update" I get a error message that source way can be found:
    JA Bulletin Module for J3.x Modul 2.6.0
    JA Content Slider Module for J25 & J34 Modul 2.7.2
    JA Facebook Activity Module for J25 & J30 Modul 2.5.5
    JA Methys Template for Joomla 3x Mall 2.5.7
    JA Newsticker Module for J3x Modul 2.6.2
    JA Popup Plugin for Joomla 25 & 34 Plugin 2.6.3
    JA SideNews Module for J25 & J34 Modul 2.6.7
    JA Slideshow Module for Joomla 2.5 & 3.x Modul 2.7.5
    JA System Social Plugin for Joomla 3.x Plugin 2.5.5
    JA Tabs Plugin for J3.x Plugin 2.6.6
    JA Twitter Module for J25 & J3.4 Modul 2.6.3
    Kind regards,
    Johnny
    Adam M Moderator
    #870452
    Hi @aaberg,
    Please edit the thread (first post), choose Require Help From Staff + Mod/Admin? then provide your site url with temporary admin account there so I can check this matter for you.
This topic contains 1 reply, has 2 voices, and was last updated by  Adam M 9 years ago.
