January 29, 2010 at 5:57 pm #148199
I’ve problems with JA Purity II and Kunena forum.
The first, there are javascript errors when the page is loaded and this break some javascript funtions. This are the errors:$ is not a function
[Break on this error] el=$(el);return(!props||!el)?el:el.set(p...entById(el);type=(el)?'element':false;}n
mootools.js (riga 23)$ is not a function
[Break on this error] return this.start( if($('ja-botsl')) rn
ja.script.js (riga 76)In some cases only the last error occour.
I’ve provided the link and the account to access the site and see the problem.The version of joomla is 1.5.15, with kunena 1.5.9.
I’ve the legacy mode enabled and yvsmiley and MosModule plugins installed.
I’ve the southbox module in the forum and in homepage.
I’ve tired to use another menù (not megamenù) but the problem persist. I’ve also tired to switch off yySlimes, southbox, MosModule and legacy mode off but the problem persist. You can see the homepage and the forum section: in the homepage no error and no problem, in the forum there are javascript errors.
With another template (JA Purity and milkiway) there are no problems, so I think that the problem is in JA Purity II.
I hope that you can solve this problem. Maybe it’s a conflict with mootools and jquery, I’m not able to debug it.The second problem is a layout conflict with Kunena default theme: you can see the difference in attached screenshot, one ok with another template, and one not ok with JA Purity II template. You can see that “Recent posts” are rendered different and maybe the font dimension are little different, but I’m not sure. You can check it by switching the joomla template and see the difference in the forum section.
Thanks in advance for your work and sorry for my english!
If you need more information just ask me! 🙂Bye,
GHz-
Viewing 1 post (of 1 total)This topic contains 1 reply, has 1 voice, and was last updated by ghz84 14 years, 10 months ago.
