  • amusal Friend
    #893614
    Hi, I have a javascript problem with the module:
    TypeError: $(…).getElement is not a function:
    [code]
    window.addEvent(‘load’, function () {
    if ($(‘jak2filter109’).getElement(‘#category_id’)) {
    jak2DisplayExtraFields(109, $(‘jak2filter109’).getElement(‘#category_id’), 0);
    [/code]
    Maybe its a conflict between mootools & jquery or something, but I don’t know what am I looking for.
    And I have another issue:
    • I have Joomla 2.5.9 & K2 v2.5.7, and I don’t know if this could be a problem, because I don’t run the lastest version of K2. My problem is that I can’t update K2 beacuse we have a modified version by us, and change the version can be painful.
    Thanks in advance,
    Alberto.
    Luna Garden Moderator
    #893914
    Could you share your site URL & admin account here so we can help you to check the problem ?
    But first you can check on site if jQuery is loaded, and version must be v1.11.3 or higher, and make sure that mootool must be loaded before jQuery, or maybe jQuery is loaded twice.
    amusal Friend
    #902836
    Firstly thank you for your reply and sorry for my late reply, but I don’t have any time until now.
    My frontend problem is solved changing jquery’s version loaded in the frontend, but now I have the same problem in the backend. I am trying to load jquery before (I tried after too) mootols javascript but the problem still occur.
    [index.p…&id=108 (línea 395, col 3)]
    TypeError: $(…).addEvent is not a function
    JADepend.inst.add(‘ja_stylesheet’, {
    [jadepend.js (línea 120, col 3)]
    TypeError: $(…).getElements is not a function
    $(document.adminForm).getElements(‘h4.block-head’).each(function(el){
    And the backend administrator doesn’t work and looks different that pictures in documentation, I use bluestork template and my Joomla version is 2.5.9.
    The module looks pretty good in demo, and I want the same in my web!.
    PS. If you don’t understand me for my english, please tell me and I could try to explain this in different way.
    Thanks.
    Alberto.
    amusal Friend
    #902850
    I solved the problem with the administration of module, by loading jquery before mootools and adding jQuery.noConflict().
    But in the administration of JA K2 FILTER component, when I press options button appears the next Javascript problem:
    ReferenceError: Joomla is not defined
    Joomla.submitbutton = function(task)
    Thanks,
    Alberto.
    amusal Friend
    #902852
    By the way, I am using com_jak2filter.v1.2.2. I guess this version is the right for me (I don’t know if there are others).
    #903254
    Hi Amusal,
    In Joomla 3.4, Mootools isn’t called anymore, you have to add it manually.
    In backend, to add Mootools, go to file:
    administrator\components\com_jak2filter\jak2filter.php
    under line:
    if(!defined('DS')){
        define('DS', DIRECTORY_SEPARATOR);
    add these lines:
    JHTML::_('behavior.framework', true);
    amusal Friend
    #906586
    Hi Luna,
    Thanks for your reply, but my joomla version is 2.5.9, anyway I have tried adding the line before but the problem still happens.
    I have finished the frontend without JS problems after all, but I have a question about indexing data. How does it works? Because I don’t have any data in these tables #__jak2filter_taxonomy & #__jak2filter_taxonomy_map. I am using Ajax search and it is slower than I expected, I think the problem is that the indexing data is not working.
    Thanks,
    Alberto.
    #906639
    You can send me your site URL, admin account, and FTP account, we’ll try to help you out.
    Yes, two above tables are used to store data for indexing, it’ll help to get the result faster. You can try to Update Indexing by:
    1. Manual: in backend >> Component >> JA K2 Filter >> Click to Update Indexing
    2. Auto: backend >> Component >> JA K2 Filter >> Options >> Indexing Data tab >> set Update indexing event to Yes, set Update indexing cron to Yes
This topic contains 7 replies, has 2 voices, and was last updated by  Luna Garden 8 years, 8 months ago.
